Humortråden
Här diskuteras allt som har med världen i skala 1:1 att göra.
Allt från den nya katten till den gamla volvon...
Re: Humortråden
Inläggav largasso 09 apr 2010, 19:59
Den här är bara bäst:
HELL EXPLAINED BY CHEMISTRY STUDENT
The following is an actual question given on a University of Washington chemistry mid term.
The answer by one student was so 'profound' that the professor shared it with colleagues, via the Internet, which is, of course, why we now have the pleasure of enjoying it as well :
Question: Is Hell exothermic (gives off heat) or endothermic (absorbs heat)?
Most of the students wrote proofs of their beliefs using Boyle's Law (gas cools when it expands and heats when it is compressed) or some variant.
One student, however, wrote the following:
First, we need to know how the mass of Hell is changing in time. So we need to know the rate at which souls are moving into Hell and the rate at which they are leaving. I think that we can safely assume that once a soul gets to Hell, it will not leave. Therefore, no souls are leaving. As for how many souls are entering Hell, let's look at the different religions that exist in the world today.
Most of these religions state that if you are not a member of their religion, you will go to Hell. Since there is more than one of these religions and since people do not belong to more than one religion, we can project that all souls go to Hell. With birth and death rates as they are, we can expect the number of souls in Hell to increase exponentially. Now, we look at the rate of change of the volume in Hell because Boyle's Law states that in order for the temperature and pressure in Hell to stay the same, the volume of Hell has to expand proportionately as souls are added.
This gives two possibilities:
1. If Hell is expanding at a slower rate than the rate at which souls enter Hell, then the temperature and pressure in Hell will increase until all Hell breaks loose.
2. If Hell is expanding at a rate faster than the increase of souls in Hell,then the temperature and pressure will drop until Hell freezes over.
So which is it?
If we accept the postulate given to me by Teresa during my Freshman year that, 'It will be a cold day in Hell before I sleep with you,' and take into account the fact that I slept with her last night, then number two must be true, and thus I am sure that Hell is exothermic and has already frozen over. The corollary of this theory is that since Hell has frozen over, it follows that it is not accepting any more souls and is therefore, extinct......leaving only Heaven, thereby proving the existence of a divine being which explains why, last night, Teresa kept shouting 'Oh my God.'
THIS STUDENT RECEIVED AN A+.
Re: Humortråden
Inläggav Storabjörnen 09 apr 2010, 22:27
Ha Ha ! Fy farao, den var bra - hade jag varit examinator hade jag också givit högsta betyg! :-P
/Sb.
Der Bär mit Das Auto.
Storabjörnen
Bad Cop
Bad Cop
Re: Humortråden
Inläggav God is Back! 10 apr 2010, 09:55
Ostrullning! Den kanske sista riktiga sporten :(
God is Back!
Re: Humortråden
Inläggav Storabjörnen 12 apr 2010, 11:03
Svårt att se hur mkt det egentligen sluttar, men det verkar onekligen slutta REJÄLT!
Osten är det första man tappar siktet på.. ha ha. Galet.
/Sb.
Storabjörnen
Bad Cop
Bad Cop
Re: Humortråden
Inläggav Nico 12 apr 2010, 11:24
Det är roligt när folk slår sig... :thumb:
Biker uses face as brake!!!!
[youtube]http://www.youtube.com/watch#!v=-bxRheMrO6k[/youtube]
Re: Humortråden
Inläggav God is Back! 12 apr 2010, 18:33
Håller mé
Ansiktsplantering + cykel = humor :D
ingen cykel, men bra faceplant :)
God is Back!
Re: Humortråden
Inläggav Storabjörnen 13 apr 2010, 08:30
Hej, använd "House of Pain"-tråden vettja, nu när det finns en! :-)
viewtopic.php?f=9&t=5449
/Sb.
Storabjörnen
Bad Cop
Bad Cop
Re: Humortråden
Inläggav Jormungandr 20 apr 2010, 10:10
--------GRILLNING----------
Efter fyra långa månader av kyla och vinter så är det äntligen vår och grillsäsongen är här. Därför är det viktigt att påminna er alla om hur det går till,
Eftersom det är den enda matlagningen som en riktig man gör.
Förmodligen eftersom det medför vissa risker (tändvätska, eld osv,).
När en man erbjuder sig att grilla händer följande:
Rutin:
1. Kvinnan handlar all mat
2. Kvinnan gör en potatisrätt, sallad, vitlöksbröd, en eller ett par såser och förbereder efterrätten...
3. Kvinnan marinerar köttet lägger det på ett fat tillsammans med de nödvändiga grillverktygen och eventuella kryddor. Sedan bär hon ut det till mannen som sitter bredvid grillen - med en öl i handen.
Här kommer det viktiga:
4. MANNEN PLACERAR KÖTTET PÅ GRILLEN.
Mera rutiner:
5. Kvinnan tar fram tallrikar, glas, bestick, servetter, underlägg och så vidare.
6. Kvinnan går ut till mannen och säger till honom att köttet bränns vid. Han tackar henne och frågar om hon kan gå in och hämta en öl till medan han försöker att rädda köttet!
Viktigt igen:
7. MANNEN TAR BORT KÖTTET FRÅN GRILLEN OCH LÄMNAR ÖVER DET TILL KVINNAN.
Ännu mera rutiner:
8. Kvinnan dukar fram tallrikar, glas, bestick, servetter, sallad, bröd, potatisen, såserna och bär ut dem till bordet där hon har lagt på en ren duk.
9. Efter maten så dukar kvinnan av och diskar.
Viktigast av allt:
10. Alla tackar mannen så mycket för den utsökta maten och berömmer honom för hans färdigheter.
11. Mannen frågar därpå kvinnan om hon har njutit av sin matlediga dag?
När han ser hennes reaktion så kommer han fram till (det han har misstänkt länge) att det aldrig går att göra en kvinna nöjd!
Re: Humortråden
Inläggav Ravajack 20 apr 2010, 18:35
Århundradets bästa uppfinning:
Ravajack
Re: Humortråden
Inläggav Dan J. 22 apr 2010, 12:15
Islands statsminister till Gud: "-I said cash, not ash!"
Dan J.
Re: Humortråden
Inläggav Ravajack 22 apr 2010, 14:54
Ravajack
Re: Humortråden
Inläggav Jormungandr 06 maj 2010, 21:59
Re: Humortråden
Inläggav Jormungandr 06 maj 2010, 22:08
Re: Humortråden
Inläggav Ravajack 07 maj 2010, 23:37
”Låten barnen komma till mig...” :-$
Ravajack
Re: Humortråden
Inläggav Ravajack 12 maj 2010, 23:42
Dé é 'nte lett å va lärare. I Amerikat heller:
____________________________________
TEACHER: Maria, go to the map and find North America.
MARIA: Here it is.
TEACHER: Correct. Now class, who discovered America?
CLASS: Maria.
TEACHER: John, why are you doing your math multiplication on the floor?
JOHN: You told me to do it without using tables.
__________________________________________
TEACHER: Glenn, how do you spell ’crocodile’?
GLENN: K-R-O-K-O-D-I-A-L.
TEACHER: No, that’s wrong.
GLENN: Maybe it is wrong, but you asked me how I spell it.
___________________________________________
TEACHER: Donald, what is the chemical formula for water?
DONALD: H I J K L M N O.
TEACHER: What are you talking about?
DONALD: Yesterday you said it’s H to O.
TEACHER: Winnie, name one important thing we have today that we didn’t have ten years ago.
WINNIE: Me!
TEACHER: Glen, why do you always get so dirty?
GLEN: Well, I’m a lot closer to the ground than you are.
TEACHER: Millie, give me a sentence starting with ’I’.
MILLIE: I is...
TEACHER: No, Millie... Always say, ’I am’.
MILLIE: All right... ’I am the ninth letter of the alphabet’.
TEACHER: George Washington not only chopped down his father’s cherry tree, but also admitted it.
Now, Louie, do you know why his father didn’t punish him?
LOUIS: Because George still had the axe in his hand...
TEACHER: Now, Simon, tell me frankly, do you say prayers before eating?
SIMON: No sir, I don’t have to, my Mom is a good cook.
TEACHER: Clyde, your composition on ’My Dog’ is exactly the same as your brother’s. Did you copy his?
CLYDE : No, sir. It’s the same dog.
TEACHER: Harold, what do you call a person who keeps on talking when people are no longer interested?
HAROLD: A teacher.
Ravajack
Återgå till Allmänt 1:1
Användare som besöker denna kategori: Inga registrerade användare och 23 gäster
